Set up / Handler 187
  • Set up / Handler 187
    I am just setting up this new Hobart Handler 187 and will be using .30 solid wire. If I am looking at the polarity right, it came wired to use flux core wire, so I guess I need to switch the wires? Does this sound right?
    One more question, what setting should I start out on the wire tension setting?
    Thanks in advance!
    For solid wire make sure the lead from the wire drive is going to positive. For tension miller's manual says to start at 3 & adjust,usually decrease, for a nice smooth feed with no slipping .Hold the gun up to a hard piece of wood & hit the trigger, if the tension's right the wire won't stop/slip & will sort of coil up. If you have the spool hub to tight you might need to increase past 3 though. The spool hub should be just tight enough to prevent the spool from "free wheeling "when you let go of the trigger. All of this is in the manual somewhere.
    Millermatic 211
    Lincoln Idealarc 250-250, water cooled tig
