New mig gun trigger sticks on
  • New mig gun trigger sticks on
    Anyone else have this problem? It's about a month old.
    I'm not familiar with the "New" brand gun.
      It's on a Hobart Ironman 230, sorry..
        Call Hobart customer sevice on Monday and tell them what ails you.
          Is the gun trigger switch staying in the depresses position when you release your finger from it?
            Yeah, it's chronic. I think the spring is n-g. Seems like it was stronger when I first used it.
              I ran into a new out of the box M-10 gun that did the same thing.I took the gun apart and found a very small piece of plastic flash was the cause.
                If you've only had the unit for around 30 days, the gun is still under warranty. So, as state previously in this thread, I'd give Hobart a call on Monday. More than likely Hobart will send you a replacement switch.
                Over the past few years I've used 3 of the H200L4-15 guns supplied with the Ironman 230 and never had any issues with the switch sticking in the closed position.
                  I thought the same thing, took it apart, filed the plastic a little but it didn't help. Seems like the spring must have slipped to the wrong position or something.. I'll call Monday. Thanks for the replies.
