Size Matters???
  • Size Matters???
    Looking for some advice on an extension cord for my welder. I have just bought a Hobart 187 and would like to rig me up an extension cord for better mobility around the shop.
    I would like to make a 15' - 20' extension cord; what gauge wire do I need?
    Bill
    Bigger is better. I run my HH187 with a 20' 10 AWG on a 30 amp breaker with no problems at all.
    -Bob (JalopyBldr)
    HH187
    13" SBL
      Thanks, I think I have some laying around.
        You can buy a 25' extension cord for round $50. Just GOOGLE "welding extension cord"
          Sow/soow 14/3 50'
            You would be fine using 12g,but if you already have 10g use it, don't waste the money on anything thicker than 10. 12/3 300V sjoow is about $. 80/ft where as 10/3 300V sjoow is about $1.70/ft, around here any way.
            Millermatic 211
            Lincoln Idealarc 250-250, water cooled tig
              I agree with Mengineer. While 14 is legal in some cases it needs to have a max breaker of 30, a 12 or larger cord can be use on circuits to 50A and personally think these little machines need all the help they can get, I am always trying to squeeze the last drop out of them anyway. The main advantage of a 10 is it may be suitable for other machines also.
                I have several pieces of 10/3 and one of them is 21, so all my cost will be for the plug and outlet.
                Thanks for the advice!
                  I don't know what's available by you but instead of using the normal plastic case 6-50r wall mount, tractor supply actually has a Hobart plug end 6-50r for $20. It's about $8 more than the wall mount at lowes, but it works better for an extension.
                  Millermatic 211
                    At that load the 187 wont even recognize its on a cord, it would work at a hundred feet or more.
