Generic Spool Gun
  • Generic Spool Gun
    I have a BetaMig 251 and weld mostly steel. I don't need to do aluminum often enough to spend a lot on a spool gun, but a local guy has a generic (Chinese...) 200 amp spool gun. It gas the welding lead, gas line, and a 4 wire cord (red, white, green, black). Can this gun work on my machine. The Hobart manual calls for a module for a Hobart gun, does the module just provide a prewired plug for easy attachment, or does the module serve another purpose? Thanks, Fred
    Fred
    Hobart BetaMig 251
    Hobart Handler 135 Mig
    Miller 330 A/BP Tig
    WP-20 water cooled torch
    Dynaflux R1000 cooler
    Linde HDA-300 AC/DC
    HP-18 water cooled torch
    Cobramatic wire feeder
    Century 295 AC Arc Welder
    SureWeld AC 225 Arc Welder
    Hypertherm Powermax 900 Plasma cutter
    Several Oxy/Acc torch and tanks
    The Betamig is DC only, right? You'll need AC for aluminum.
    I see you list a Miller 330 A/BP Tig in your sig... why not use that?!?
      Don't know anything about that spool gun but just to clarify mig welding of aluminum is done in DC not AC.
      Ken
      Power Mig 350mp
      Python push/pull
      Passport
      Miller 625 Plasma
      Miller spot welder
      Ellis 1600
      Grizzly 20" drill press
        Oops! I was thinking TIG.
        As far as I can tell, the "module" is just a plug.
          Thanks guys, always looking at new ideas..
          Fred
          Hobart BetaMig 251
          Miller 330 A/BP Tig
          Linde HDA-300 AC/DC
