Flux cored welding with CO2?
  • Flux cored welding with CO2?
    I was talking to one of the guys at the local welding supply shop yesterday about any recommendations he had for welding 1/4" to 1/4" with my 140 other than the proper prep, beveling, and multiple passes. He said that since I'm using flux cored wire that adding Co2 would help penentration and make for less cleanup. Does this actually work? Or would I be better off saving the money and doing a really good prep job? Pros and cons? thanks guys
    HH140
    Score one more piece of abonimable advice from a LWS Counter Expert.
    Flux cored wires that are designed to be self shielding do not benefit from running CO2. In fact, in most cases it can be detrimental and cause changes in the metallurgy of the filler metal. There is no gas-shielded flux core wire (sometimes called "Dual Shield") that will run on a Handler 140 and there is no self-shielded wire that's designed to run with additional gas shielding.
    Oh, and I can't believe you actually asked if you'd be better off just doing the job correctly, but... yes. You would.
    Hobart HH 125EZ
      It's also possible that he misheard you and thought you weren't using flux cored wire, hence his recommendation for you to use CO2.
        ok thanks guys. lol I can't believe I said that either now that I think about it. I planned on doing a really good prep job anyway. So far I've cleaned the surface as best as possible, before and after every bead Like you guys say, prep is everything.
        Don't think he misheard me. I specifically told him I was using flux cored wire because all of my welding is outside. Who knows what he was thinkin... that's the exact reason why I asked since most of you guys think counter monkey's don't know jack sh*t.
        Speaking of prep work, other than grinding, brushing, beveling, etc, would it benefit me to clean the surface with acetone? I've been reading the "Welder's Handbook" and it's recommended a few times. Is there something better to use?
        HH140
          I also have the "Welder's Handbook". One of the other recommendations the author makes is to use a metal etching solution created from Muriatic Acid. I was able to find the acid at Ace Hardware, and used a diluted solution to prep some metal. It worked very well for removing light rust.
          Just make sure you have lots of ventilation and wear eye protection and gloves. I sprayed it on some mild steel in my garage with the door open, then left for about 10 minutes to let it work.
            Thanks I'll have to look into that.
            HH140
              Oh, yeah... about Finch's book... you might want to take things you read in there with the same caution as LWS counterman advice...
              Hobart HH 125EZ
                Was that wink purely for sarcasm, or does that guy actually give some sketchy advice? I only ask because it seemed like a pretty good high-level overview of welding, but having no formal training I can't say if the material he teaches was good/bad/bs/otherwise.
                I try to be a little skeptical of everything I read.
                  Could not have said it better. Flux core is fluxed already. Period!
                  Millermatic 135 110v .030 Flux-Core Wire
                  Have a Jeep Cherokee? Click Here!
                    I just read some of the Amazon reviews for "Welder's Handbook" and there are a few bad reviews that point out inaccuracies and so forth.
                    I found it helpful, but looking back I do agree there could have been more photos of welds and welding techniques and less pictures of clean shops, etc.
                    I also remember looking at the welding cart plans thinking it would be a good first project, but I couldn't figure out how to build some of it. Keep in mind someone that's done this type of work before would probably find it obvious, but being a beginner I found myself wanting more pictures of the finished product from multiple angles, and more drawings showing different parts of the table, how they fit together, and how to approach fit-up and welding.
                    I've heard many times on this forum that the Miller educational $25 kit is worth every penny. I found some great technical info on MIG at the ESAB site as well: (http://www.esabna.com/EUWeb/MIG_handbook/592mig1_1.htm)
                    Any suggestions on other welding guides?
                      I've been having the same problem with this book. It's almost like he's avoiding the part about actually laying down a bead. There's a serious lack of useful pictures.The biggest thing that's killing me is that all he talks about is airplanes and racecars. Right now I'm getting more info from everyone on here and using the book more for the theory than a guide.
                      HH140
                        Finch
                        talks about.......
                        himself and the companies that provide him with ????
                          good point. My co-worker lent me a book called "learn how to weld **** near anything" by jessie james. Looking through it it was actually written by finch and was almost identical to the welders handbook.
                          HH140
                            I wrote the review on Amazon that pissed Finch off so bad he registered there just write a rebuttal.
                            Hobart HH 125EZ
                              Novanate70,
                              Are you actually having problems? or are you just imagining problems you don't have?
                              Most flux-cored wires, will handle a certain amount of contaminants, whether mill-scale, a little rust, a little oil.
                              Same for most stick rods. Likewise, up to a point, even mig wires.
                              You should stop reading, start running beads, if necessary, just practice beads, and break them open, look inside. Practice and observation will teach you much more than reading, or advice, from unqualified people.
                              *** Disclaimer ***
