Lincoln Power MIG 180C vs 180HD?
  • Lincoln Power MIG 180C vs 180HD?
    Any ideas what the differences are between a Lincoln Power MIG 180C and a Lincoln 180HD? I know the Power MIGs are sold at welding shops, while the 180HD and 180 Pro MIGs are sold at Home Depot/Lowe's. From what I can tell, all of them accept a spool gun, but I cannot determine what the differences are among these 180a welders.
    Thanks!
    Well for one thing, the HD model is a tapped machine, whereas the 180C is a continuous "C" adjustment.
    Lincoln 175HD
    Miller Thunderbolt AC/DC
      the Power Mig Cmodels offer a Cast AL drive roll system- mo' robust
      .. as well as having Continuous Voltage selection
      ... where as the SP180T, 180HD etc have a Tapped Voltage selection
      180C
      "Professional Features:
      • Industrial Cast Aluminum Drive features:
      – Dual gear-driven drive rolls for positive traction.
      – Patented split wire guides for optimal wire alignment.
      – Brass-to-Brass gun connections for enhanced connectivity.
      – Large industrial closed-design drive motor for improved torque and trouble-free performance."
      180HD, SP 180T etc
      • Precise Wire Drive features:
      – Precision full adjustment drive system reduces chance of wire tangling and crushing.
      Ed Conley
      Screaming Broccoli, Inc
      MM252
      MM211
      TA185
      SO 2020 Bender
      Miller 125c Plasma
        Thanks for the responses. I have a chance to pick up a new in box 180HD for $450, and I wanted to see what the main differences were between it and the Power MIG.
        How would this unit compare with the HH187? I know the 187 is a 7 tap, whereas the HD is a 5 tap. Other than the number of taps, any significant differences? I believe TSC is running a special on the HH187 for $599, but I can get the Lincoln for $450.
          They always will tell you to buy big...that being said I really like my 180HD(was the biggest they had here)
          btw I had to pay a lot more then that for mine
            Spend the additional $149.00 for the Hobart.The extra you paid will be quickly forgotten once you start using it.
