First off I will start with a nice link that describes the kit a bit better than I could.
http://www.autocarepronews.com/defau...=art&id=91535&
Chris Croatt, Hobart Product Mgr., was kind enough to send a complementary kit in exchange for some feedback. Well, here is my feedback upon this neat little kit.
One for reference in case you aren't sure of the actual size of a paintball tank
I am a very new user to MIG welding. I've had my HH140 for about a month and I just about burned through the whole roll of 030 Flux Weld-It wire that came with it. I was very excited to entertain this kit for its portability as I've quite a few projects that absolutely require me to transport my setup. Not only is this kit ultra-portable (barely even notice its installed) but this little 20oz tank "should" last 30-40 minutes of welding time and it only cost me $3.50 to fill it at my local Sports Authority (anywhere they've paintball supply/bicycle equip).
Here is my HH140 atop my homebrew/junk cart that I made up with garbage and parts lying on the side of the house.
The kit installs on the right-most side vents so as to not block all of them when its all bolted up. These two simple brackets slip right into the upmost vent and the 3rd from the bottom on the right side. This is all that is required as backing and support for the bracket to hold the extremely light tank.
Two screws and the two brackets and you are good to go.
Remove your caps.
Remove your caps.
