handler 187 wire feed problems
  • handler 187 wire feed problems
    hello i purchased a 187 to replace my previous welder i seem to be having issues feeding the first roll of wire in. it is fine all the way through the liner but, it seems to be getting caught in the gun
    any help would be great. oh this is a re manufactured machine. but the first roll i put through it.
    Have you tried screwing off the tip while feeding the wire through the gun? If not, take it off, thread the wire through the gun, place the tip over the end of the wire and thread it back onto the gun. Also, check to make sure the tip is the correct size.
      no tip, the gun and cable as straight as can be after the first birds nest.
        This isn't with aluminum wire is it? I mention it only because you said something about bird nesting.
        New/remanufactured gun with no tip installed? Tried running a short length of wire through the gun in reverse to see if there is a problem? If you come across a blockage while reverse feeding the wire, carefully note how much wire is inside the gun and see if it doesn't come out to be about the same length as the distance from the liner end to the tip. Your liner may be crimped at the connection, otherwise defective gun.
          I GOT IT i did not push gun all the way in the machine once i read the ------- manuel did i get it.
          thanks for your help. i was wondering why it was harder to feed wire then my old machine.
          this machine is awesome like night and day vs old machine.
            Congratulations! Glad to hear that the manual saved the day. We would all be further ahead if we took the time to read the darned things..."Gimme...wanna play...NOW!!!!!"...least that is how it goes around my shop much of the time until something doesn't work right.
