I am building an SS exhaust and I am wanting to tack everything up and then take it off and get it TIG welded. I have is a 75/25 mix with MS wire, will this be ok to tack it up?
Tack 409SS with MS MIG
Originally posted by 01somta View PostI am building an SS exhaust and I am wanting to tack everything up and then take it off and get it TIG welded. I have is a 75/25 mix with MS wire, will this be ok to tack it up?
Originally posted by Rocky D View Post3 tacks should be all you need, but like kst says it will rust in the tack area, but it wouldn't make the pipe fail. You might also consider getting SS fluxcore wire to tack it with.
Originally posted by kst8engineer View PostSS fluxcore wire is a great idea, I hadn't even considered that. I actually could use this in a project I've got coming up as well... Thanks for the suggestion, Rocky D!Trailblazer 302 * Millermatic 212 * Syncrowave 180SD * X-Treme 12VS Feeder * Spoolmate 3035
Hobart HH 125EZ
Rocky,
Maybe you'd be so kind as to post up some sources for SS fluxcore wire in sizes useable by the average (non production) guy.
Only SS fluxcore wire I've found was on 44# spools and that would last me about three lifetimes. That, and the fact that I'd have to mortgage the house to pay for a spool that large.
If you have a source for 2# or even 10# spools, I'd sure like to hear about it. Oh yeah, 316 would be nice.SundownIII
Syncrowave 250DX, Tigrunner
Dynasty 200 DX w/CM 3
MM 251 w/30 A SG
HH 187 Mig
Dialarc 250 w/HF 15-1
Hypertherm PM 1250 Plasma
Victor, Harris, and Smith O/A
Mil Mod 6370-21 Metal Cut Saw
Grizzly 6"x48" Belt Sander
Miller BWE and BWE Dig
https://weldingsupply.securesites.co...49:UNDEF::::PC
[edit] Sorry, I spoke too soon -- they're not fluxcore.
I'm building an exhaust system using components which are 409 stainless steel, and it would be very nice to be able to at least tack weld the components together at home (without ending up with rusty welds). If I could come up with some flux-cored stainless steel wire, I'd probably just weld the whole thing myself. My only welder is a Hobart Handler 135 MIG.
So, if someone does run across a flux-cored welding wire available for a reasonable price, I'd be interested in it as well.
What about the possibility of welding 409 stainless with 308L wire? ER308L is considered to be an acceptable wire for welding 409 SS. It's not a fluxcore wire, so a shielding gas will be needed.
What is the preferred shielding gas to be used with ER308L? Does anyone have experience using ER308L with a 75/25 Argon/CO2 mix? Although this gas is probably not the preferred shielding gas, would it work with acceptable results?
Originally posted by kst8engineer View PostWhat about the possibility of welding 409 stainless with 308L wire? ER308L is considered to be an acceptable wire for welding 409 SS. It's not a fluxcore wire, so a shielding gas will be needed.
