Purchased a Hobart187 connected to 30A double pole breaker. Problem, when I start to weld, I get an initial "spark" but nothing after that. The circuit breaker has not tripped and the fan on the unit is running but no further spark. Do I need to run this unit off of a 50 A breaker or is something in the wiring??
Hobart 187
30 Amp breaker is fine. Check your ground connection, and be sure polarity is correct. From the factory, the machine is set up for flux core; you neeed to reevrse the lead for gas. Also check the pressure at the feed roller and on the spool. Do you get good wire feed?
Originally posted by badkins View PostPurchased a Hobart187 connected to 30A double pole breaker. Problem, when I start to weld, I get an initial "spark" but nothing after that. The circuit breaker has not tripped and the fan on the unit is running but no further spark. Do I need to run this unit off of a 50 A breaker or is something in the wiring??Millermatic Passport Plus
Millermatic 200
Millermatic 350P with Python
Dynasty 300 DX
Victor O/A
Hobsrt 187
Thanks crawler and cope, The polarity is correct (for DCEN)and wire appears to feed easily. I "think" I'm getting 230, hopefully it's the ground although I moved it to multiple areas w/same results. Nice to get reply from experts without sarcasm and insults like "Other" forums. I'm new at this and trying to learn. Appreciate the advice.
Be sure that the ground clamp is tight on the end of the cable also. You should be able to aim the gun at a 2x4 at a 45° angle and see the wire feed out to the board and then curl up.
Another thought, disconnect the power cord. Take the cover off the machine and make certain that all connections are tight. Some times things come loose in shipment.
Check this thread for a similar problem, in which a Hobart Expert offers several possible causes:
http://www.hobartwelders.com/weldtal...ad.php?t=31892
Personally, I'd skip straight to calling Hobart and talk with their tech guys.Trailblazer 302 * Millermatic 212 * Syncrowave 180SD * X-Treme 12VS Feeder * Spoolmate 3035
Hobart HH 125EZ
Originally posted by Zrexxer View PostCheck this thread for a similar problem, in which a Hobart Expert offers several possible causes:
800-332-3281
Check your gun both ends, maybe the cable has been pulled out from one end,would normally be the plug end, check that the contactor is closing, if it is then you would be getting gas flow, if not no gas and no arc, or it may not be closing properly, also try moving the voltage selection switch to each position a few times then try welding again on each position, problem could be on the input side of switch if it hasnt been used for a while
Cheers
There one more question that I'd like to ask. I know it's pretty simplistic, but did you install the tip in the end of the gun.
I ask because we do get this type of question and find that there's no contact tip in the end of the gun. The contact tip creates the electrical contact with the welding wire, making it electrically hot.
Darrell
