I'm looking at buying a 33# spool of ER70S-6 wire (hobart brand). I found a much better price on the same wire and brand, on a 45# spool...but I'm not sure if it will fit. The 45# spool about $20 cheaper then the 33# spool...which is why I'm interested in it.
I'm guessing that the HB-28 33# and 45# are the same 12" diameter...just with more wire?
The spool is not local and the seller said the spool is 12.5" in diameter. I've measured my beta-mig 200 and it looks really tight...I'm not sure if it would clear or not. This is the econo-spool (wire frame), not the wood or plastic type.
I was hoping someone here might have run this type/size spool through this model machine already. I didn't see anywhere where it mentions the max spool diameter in the manual.
Thanks.
Thanks.
