looking for some info on a blackhawk mig welder relay that powers the wire feed motor there are two of them on the board one controls motor other controls welder transformer.both are the same and all that is on them for a number is KH/U 30 pAsi looking for any help or info on this relay or welder
mig welder relay
I would go to an electrical supplier as mentioned and see what they can do. They may be able to identify it with just the part number. Do you have a schematic for this machine? If you could determine what input and output voltage you need you may be able to give them enough info to supply one. As I mentioned the pin format looks pretty standard for commonly used bases.
Try this link to see if these will work.
http://search.digikey.com/scripts/DkSearch/dksus.dll
You will need to determine your coil voltage.
Keith
