I have a Handler 187, it does a good job and has been a good welder for me, until the other night I went out to spot a couple peices in place on a frame I've been working on. The wire wasnt feeding. I checked everything out and the drive itself was just not turning. I waited til today, when it was 55 outside, and tried, still not feeding, so I took the case off to look for any simple problems (unplugged wire,etc). While I had the case off, I cranked up ther wire speed and pulled the trigger, fire literally shot out of the side. I unpluged the machine and found [I beleive] a diode on the upper PC board with a hole burnt in the side of it. So I found my problem,or at least a result of my problem. I dont know if anything off of the board could be in error, but obviously a big burnt spot isnt good.
Has this happened to anyone else? This really sucks because I needed to put in alot of hours over these 2 warm days to make up for the last cold week and the following cold week.
Everything else, to my knowledge, is working fine. I've owned this machine for about a year, so I'm sure the problem is covered under thr 5 and 3 year warranty,but the nearest service center is over an hour away. I'd like to just get things figured out before I take it out of state to an unqualified repair shop (trust me, thats how it normally goes around here) if this is a common failure.
Anyone have any input? I'm hopeing the only damage is on the pc board, as I'm certain it has a part number for itself and can be simpley removed and replaced,either by me or the shop.
thanks for any adivse/suggestions or comfort, Andrew
