Hobart wire
  • Hobart wire
    Picked up a 2 lbs spool of .030 HOBART wire this evening, from the farm store, to try out tomorrow evening.
    I am wondering what the "Packaged in USA" on the label translates into meaning. "Made in China" and wound onto a smaller spool in the USA possibly?
    The 10lbs spools were all marked "Made in China". As is the roll of .030 that I already have here at home. I've ran several pounds off this roll and admittedly it has performed real well in the areas of arc quality and puddle wet out.
    I don't care where its from as long as it works like it is supposed to.
    Don
    Go Spurs Go!!!!!!
      Don,
      I just found it amusing that effort was spent to place the Packaged in USA on the label.
      The 10 lbs spool runs real well on the loaner HH 210 that I have, and my HH 187. Noticably better then your Pinnacle in the area of weld puddle wet out. Compared to to HB-28 or this Hobart wire, the weld puddle wet out of the 3 rolls of pinnacle wire that I have is a little sluggish. I'm not stating the Pinnacle is a bad wire, I just prefer the Hobart wire.
        I didn't have any issues with the Hobart wire. Spatter was a tad higher than the Pinnacle, but not bad. May just be a machine difference. Dunno. I will say this much, my 250+ isn't impressed by the Pinnacle at all. Spatter city. Radnor is just as bad and the Thermal S-6 is nothing but BB's. Hobart wire ran much better in the 250+ than anything. Looks like I'll be going back to Hobart everything once I run out of all the rest in the shop. My TB and feeders are the only Millers I have left, so the Pinnacle isn't as great a deal as it was. Still runs great in the HH210 at least. Now I wonder what I am going to do with the new 33# roll of .030 I still have.
        Don
        Go Spurs Go!!!!!!
          It probably will run in my Lincoln just fine.
          Esab 2200 AC/DC
          Thermal 211i
          Thermal Pee-wee 85s
          Smith O/A plus mini torch
          Smith machine torch
          LN-25 pro
          LF-72 feeder
          Edwards 65 ton
          5X10 CNC table
          Victor A-120
          Miller Shopmate 300DX
          S-74D feeder
            That sounded like a hint.
            Don
            Go Spurs Go!!!!!!
              Send it to me!
                Dang...they are lining up!
                Cope, do you ever see Pinnacle around you? I was just wondering since the distributor is in Houston.
                Don
                Go Spurs Go!!!!!!
                  I've had pretty good results with the Hobart wire too.
                  Hobart Handler 210 mig , 80cf bottle of C-25 mix
                  Bokrand GmbH pocket mig , 110v
                  Clarke 101E stick , 110v
                  Craftsman 10" drill press
                  Craftsman 12" bandsaw
                  HF 12 ton hydraulic press
                  Black Max 6hp 60gal air compressor
                  2 4 1/2" grinders
                  Porter Cable 1410 ,cold cut chop saw
                  Makita 14" ,abrasive chop saw
                  50ft 8/3 extension cord
                  Makita saw
                  Arctic Cat generator with adapter cable for welder.
                  Eastwood 135 mig 110v , 20cf bottle C-25 mix
                    No, but hum a few bars...
                    I haven;t bought a spool from a LWS in years. I have a 33# spool of .035, two spools of .030 and a few 8" .030 and .035. Whenever someone mentions a good wire, I can never find it locally, who is the distributor?
                      http://www.sowesco.com/
                      That is who my LWS gets it from.
                      Don
                      Go Spurs Go!!!!!!
                        Was it solid wire or flux cored wire?
                          Most likely it was solid.
