Does anyone know where i can get a 3035 spoolgun for a hh187. I used the where to buy option but only get one result. thanks in advance
spoolguns
You wil aslo need the SG100 controler...try ebayGeorge W. Bush saving your butt whether you like it or not!
Thomas Paine
HH210 w S.G.
Victor/Uniweld O/P
Dewalt Chop Saw
I think B&R welding supplies sells a kit to retrofit the miller spoolmate 100 to the hobart 187. The only issue with this is I believe it voids the warranty.
http://www.brwelder.com/indextemplat...ubCategory=269
Originally posted by vtech View PostDo I need the kit for the 3035 spoolgun? In the products section it says that gun is for the handler 140,187,and ironman 210 is this right or did i misunderstand. Thanks for the help guys.
It is, but for the 140/187, you need the kit. I am not sure about the IM210.
The HH210,IM 210 and IM250 are direct plug units....the HH140 and 187 need the controller.....George W. Bush saving your butt whether you like it or not!
Thomas Paine
HH210 w S.G.
Victor/Uniweld O/P
Dewalt Chop Saw
here are two 3035's. The DP version is for the handlers, and replaces the MIG gun.
The Miller version connects through a controller for all machines other than a MM210 and up.
Hank...from the Gadget Garage
MM 210 w/3035, BWE
HH 210 w/DP 3035
TA185TSW
Anyone crossbrand a spoolgun?
I saw online that there was a Lincoln Electric K2532-1 Magnum 100SG 10' Spool Gun through toolsforless.com It's selling for $180 would it not be worth modifying to work with a HH140?
I'm definitely new to welding but I'd like to get a spoogun for aluminum. I understand "you get what you pay for" but wow the price on those things...
Thanks!
Originally posted by rooftoplounge View PostI saw online that there was a Lincoln Electric K2532-1 Magnum 100SG 10' Spool Gun through toolsforless.com It's selling for $180 would it not be worth modifying to work with a HH140?
Thanks!Esab 2200 AC/DC
Thermal 211i
Thermal Pee-wee 85s
Smith O/A plus mini torch
Smith machine torch
LN-25 pro
LF-72 feeder
Edwards 65 ton
5X10 CNC table
Victor A-120
Miller Shopmate 300DX
S-74D feeder
Tractor supply has the spoolgun online for $199, lists it for the HH210, can you get the other parts from Hobart to add it to the HH187?Hobart Handler 210 mig , 80cf bottle of C-25 mix
Bokrand GmbH pocket mig , 110v
Clarke 101E stick , 110v
Craftsman 10" drill press
Craftsman 12" bandsaw
HF 12 ton hydraulic press
Black Max 6hp 60gal air compressor
2 4 1/2" grinders
Porter Cable 1410 ,cold cut chop saw
Makita 14" ,abrasive chop saw
50ft 8/3 extension cord
Makita saw
Arctic Cat generator with adapter cable for welder.
Eastwood 135 mig 110v , 20cf bottle C-25 mix
