First ever HH210 problem
  • First ever HH210 problem
    Serial number is LG210009Y.
    It welds just fine, but now when I go to tap #2, there is no output or wire feed. All other voltage taps work just fine.
    If no ideas, I'll give Hobart a call this week, but maybe it's something simple?
    Obviously you were trying to use it in an application where Tap #2 was not the correct voltage, and the HH210 is so smart that it disabled itself on that setting to protect your weld quality.
    Actually, I got nothin'. I have no doubt though that the Hobart Experts will do what they do, and get you fixed up.
    I'm guessing you're back stateside now?
    Hobart HH 125EZ
      Mac,
      Have you pulled the cover yet and looked for a disconnected wire ?
      Have you checked the sector switch out with a meter?
        Mac,
        Like Dan said, check the switch for a disconnected wire. If all appears good there, it most likely is the switch. Give us a call and we can get you fixed up.
        Keith
          Ya,,, but,,, who would he find qualified to replace a switch???
            I think we could trust Mac to handle that if need be.
            Keith
              Another likely suspect, also targeted at the selector switch, would be a loose connection at the wire that goes to the #2 position. Also, on the opposite side of the switch, there's a bussed common connection. Check for loose screws on that bus as well.
                Check wire terminals for evidence of heating first, then try blowing out the switch with compressed air but try not to blow crap into it and you could try spraying some contact cleaner into the switch while rotating it to different positions. Then blow out any excess contact cleaner and try it again. Failing that replace switch
                Cheers
                  When you get it fixed, please let us know what is was. It is allways good to be able to search and find fixes.
                  Victor Superrange II OA
                  Harris Port-A-Torch
                  Lincoln AC/DC 225/125 Tombstone
                  Miller Thunderbolt AC/DC 225/150
                  Miller 211 Autoset
                  Hypertherm Powermax 30 (newest toy)
                    Okay, sheet metal is finally off and all connections are tight on that switch. I double-checked the one that the schematic shows as belonging to position #2. I can feel no difference when switching through #2 compared with switching through any of the other positions. There is still a big click when the trigger is pressed but there is no wire feed and no weld voltage.
                      If you have a volt meter handy, measure the AC voltage on the back of the switch when the switch is in the 2 position.
                      Measure between terminal #11 (common) and terminal #4. If you have about 230V then the swith is bad.
                        Nah. Hobart Expert Keith messaged me that the switch is bad and has already mailed the new one. Now, if the new switch doesn't fix it, I might be tempted to poke things at it...
                          New switch is here. Nobody better be timing me on how long it takes me to get off my *** and swap 'em...
                            Got 'er done yet, Mac????!!!
                              Done yet Mac??
                              You taking the day off???
                              SundownIII
                              Syncrowave 250DX, Tigrunner
                              Dynasty 200 DX w/CM 3
                              MM 251 w/30 A SG
                              HH 187 Mig
                              Dialarc 250 w/HF 15-1
                              Hypertherm PM 1250 Plasma
                              Victor, Harris, and Smith O/A
                              Mil Mod 6370-21 Metal Cut Saw
                              Grizzly 6"x48" Belt Sander
                              Miller BWE and BWE Dig
