I have a Hobart Handler 140. When the unit was new I had no trouble welding aluminum...but now it beads up and will not weld. I have the polarity set at DCEP, 100% Argon gas, cranked to the max and it cannot run a puddle.
Is there anything in the unit that would break down and change the polarity?
Any ideas on this problem...it welds steel just fine with solid or flux core wire.
Thanks!
Reason: duplicate post
It turned out to be the liner was dirty (Bad from the flux core) and the O Rings were shot, and the main lead had gotten pulled out enough to see the first O ring. Thanks for all the help. Sorry it took so long to get back. Machines working good again!
