Don,
While you're patiently waiting for you new machine,
I decided I 'd torment you
with a couple weld bead pics produced with my inferior yellow unit.
For these welds, I had the coarse voltage dial set to the high range, and the fine range voltage dial set to tap #2. The wire speed dial was set a little short of 8. I feel a good guess on the out put for these setting would be 24 - 25 load volts with an amperage that falls in the 200 -210 amp range.
