One of my young friends has an automotive machine shop here where I live and needs a foot pedal for his Lincoln 300/300 tig machine...anyone got one that works for sale......
I have a like new one. Do you know the part # that you need? Mine is a L3963-7. I will sell it for $80 plus actual shipping. stronicsatallteldotnet
Thanks,
David
When he bought the welder it didn't have a pedal...all it has is a thumb switch on the torch.....How
many pins does your pedal have? (picture would be great)
The machine is an older tig300/300 (Big gray colored ) code # 6187-CH Ser# AC-265400
The foot pedal looks like a three prong regular wall plug....I need some pictures to match things up .....Hope this info helps
My machine is identical on the outside, just a bit newer (Code 7499-c, SN AC-343412).
In the picture you've posted, I can see clearly see the plugs I mentioned. Directly above the decal "IDEALARC", are the 2 "wall plugs" for 115V AC. Directly above them you can see two bright spots. The upper left spot is the 5 or 6 pin connector for the foot pedal. The spot next to it is the selector switch for the pedal.
Thanks,
David
I am interested in the foot peddle .Does it have 5 pins? Thanks Larry
