auto body welding
  • auto body welding
    Hi , I recently started welding 18 to 20 gauge auto body steel using a recently obtained used Handler 140 . I am getting the best looking welds with a number three voltage position , 25 cfh gas and 35-40 wire feed using a thin flexable copper back up . Using .023 solid wire and 75-25 gas . Does this sound right and has anyone else come up with like settings ? Any other tips are much appreciated . Milton in Franklin , WI
    did you switch this machine for solid wire? that setting is way hi.
      Just went out to double check , yep , set according to the picture for solid wire . ?? Lower settings leaves an external narrow beaded up weld . Could it be a low supply voltage caused by it being on a 15 AMP GFI cicuit ?
