Hi,
I have an XMT 300 cc/cv that doesn't power up at all. Plug it in, turn it on, nothing happens. I've checked everything as suggested by the tech line and manual, but can't pinpoint the problem.
Things that are obviously wrong: The relay coil on the line in is not getting any voltage, so it's not turning on. Voltage on the input capacitors is zero all the time also. Seems like whatever turns on that relay coil is the problem. Is there a way to test, or bypass safely, the "Auto-Link" board?
