Grinding welds
  • Grinding welds
    Does the built up material of the weld offer any benefits or should all welds be ground down. Does it weaken the weld if you grind it down?
    Sometimes yes, some no, maybe yes or no, ha.
      Um...thanks . Could you clarify please! Thank you!!!
        Depends
        If you welded it for maximum strength then don't grind, if you want strong and pretty then grind. IF the weld was done CORRECTLY even ground, it should be at least as strong as the base metal.
          Thanks for the input. How do you know if it was done correctly? I'm a beginner so any input is appreciated.
            A lot depends on the application, take a guided bend test for example, all ground smooth. All these beam splices ground.
              volsfan,
              Give these videos a looksee. They may be of some help:
              Welding Videos: GAS/ARC/MIG/TIG/FABRICATION/METALS/WELDING SYMBOLS
                Thanks Danny!
                  Video Link
                  Thanks for the video link, very good.
                  Miller 140 A/S
                  HF Flux Core
                  Dewalt Chop Saw
                  Smith O/A Torch
                  Ryobi Grinder, Craftsman & HF Grinders
                  Harley Electra Glide Classicsigpic
                    He answered it with the same clarity as the question...
                      Any metal in excess of the parent thickness is a waste.
                        It never strengthens a weld to grind it either.
                        Jim
                        Miller MM 210
                        Miller Dialarc 250P
                        Airco 225 engine driven
                        Victor O/A
                          WARNING! WHAT FOLLOWS IS A PERSONAL OPINION BASED ON LITTLE FACT.
                          If the weld is on something where strength is of the utmost importance, chances are cosmetics are not important and grinding the weld is a bad idea.
                          If the weld is on something where it's important to have a nice cosmetic finish, then chances are strength isn't the main issue and grinding is OK.
                          Lincoln Idealarc 250
                          Lincoln Weldanpower CC/CV engine drive
                          Lincoln LN-25 wire feeder
                          Miller Syncrowave 180 SD
                          Various oxy-fuel setups featuring Victor, Harris, and Prest-o-lite products
                            Thanks Danny!
                            Your welcome, Volsfan. I am sure those videos will be of help.
                            To answer your question more directly, I'd practice diligently, then it won't matter if the weld is structural or not with regards to typical requirements.....there will be no need to grind a good weld. With proper practice and proper metal prep, your welds should enhance the appearance and also enhance the strength of the welded area. My $.02
                            FormerTankSarge, no problem.
                              There are lots of places where welds are ground and basically for strength especially where there is working action. These are usually full penetration and they want to eleminate cracking next to the weld. This is not a "no never" or "yes. always" question, sometimes grinding improve the strength. Maybe not in a purely tensile pull but there may be other factors.
