.023 v. .024?
  • Roger
    Buy cheap dial caliper to see real size of your wire. Most times .024 wire is .023. I have .023 Chicago Electric wire made in Italy that is .022 and requires different settings.
    I ask Georgia tourists how goes the civil war and they reply not them this time.
  • bandsawguy
    Originally posted by Mike C2 View Post
    It will work no prob with the tips. But the .024 is 4.35% larger in diameter. With my 15 ft gun on my Century 250, the .023 jams up on itself all the time. I switched to my Miller 140 with the same spool thinking it's shorter gun would help, but I had feeding problems there as well. The .024 feeds much more reliably, but I guess my .023 spool could have a problem? I was in the same situation when I bought the spool of .023. But next time I'm getting the .024 for sure.
    Mike,
    check the roller in your machine. 023 024 all run ok in my Century welder.
  • Mr Meck
    Pay attetion to the roller size, liner size and tip size as well.
  • crawler
    Are you running different brands of .023 and .024 wire? I wonder if the .023 wire is an imported wire.
  • Mike C2
  • ScottB
    Great!
    My thanks to both of you.
  • Bob the Welder
    It'll never know the difference! Less than 1/3 the thickness of a sheet of paper difference.
  • aametalmaster
    YUP...........Bob
  • ScottB
    started a topic .023 v. .024?
    .023 v. .024?
    My Handler 125 came with a small roll of .024 solid core wire. When I went to purchase another roll at my local supply house, they only had .023. Will that work with the tip that came with the Handler 125?
    Thanks!
