HH140 Replacement Gun Assembly
  • HH140 Replacement Gun Assembly
    How much would the entire gun and cable assembly cost? I am looking at a hh140 in the paper. It does not look used at all. The cable assembly was broken at the front of the machine. I intend on taking a jumper wire to make sure the contactor, drive motor, etc work.
    Bobby
    HH180
    http://www.kswoodwork.com/
    I seem to recall they were about $100, but they must have hiked the price at cyberweld since I last looked.
    http://store.cyberweld.com/h10miggun.html
    I see some new ones on eBay for about $130, and if you can find one used you could probably get it below $100.
    Lincoln 175HD
    Miller Thunderbolt AC/DC
      Thanks for the ballpark estimate. I think it might be worth going a checking out.
      HH180
        If the cyberweld ad is correct, you can check it out with your HH 180 gun. The HH 180 literature on this site also seems to say the 180 uses the same gun.
        Lincoln 175HD
          http://www.weldingsuppliesfromioc.co...let/Categories
            Bobby, smyrna5 is correct, take your H10 gun from your HH180 with you to check out the unit, same gun.
            Brian
