Create a Bootable USB with Etcher
  • Create a Bootable USB with Etcher
    {Etcher is a program which permits you to create bootable USB devices easily. |} Therefore, in the event that you prefer to use Etcher, the first thing you should do is download the program from its official site utilizing the following links.
    Etcher Download Links:
    https://etcher.download/
    https://www.balena.io/etcher/
    https://wiki.ubuntuusers.de/Etcher/
    Following the setup has downloaded, install it and open up the software.
    Now you need to connect the USB device that you are going to use. {Even a USB device with 8GB capacity is usually enough. |} But I urge a 16GB USB 3 device because it makes things easy and fast. And also you replicate your drivers to it.
    As from the picture below, simply select the .ISO picture of this operating system where the USB drive will boot.
    Bear in mind that through this procedure all of the information in the USB device will probably be deleted. If everything is correct, click on Accept and then wait for the process to complete. It is going to take a couple of minutes.
    Garbage, would not be surprised if it contains a virus ...Not needed here ... And it can destroy you computer's operating system and cause all data to be loss if goes haywire....
      Total garbage and spam! Dont down load it or open it up if you have already done so!
      A few of my toys !!!
      MX Linux
      LinuxMint
      Miller Roughneck 2E
      Lincoln Weldpak 100
      Gianttech Arc 200
      Victor O/A
