Danger.... Listen to the Little Voice...
  • Danger.... Listen to the Little Voice...
    When the little voice in the back of your head is trying to tell you something listen to it.. IT was saying. "Son it might be good idea to check the wheels on the grinder....
    Did it fall apart like that as you took it off?
      Looked at it while mounted and could see hair line cracks, as I took it off, yes it came apart....
        Just tighten the mounting nut a little. Geez. And inject some glue from the side so you don't have to fight the dried ooze on the grinding face.
          Perfect quarters - amazing. Makes it easier to duct tape back together.
            Dale, you are one LUCKY guy!
              That’s exactly why I forgo the safety glasses for a shield and always tuck it down or cover my neck area.
                Well, you really should wear safety glasses under a shield. I'm amazed how much stuff gets behind the shield.
                  Wear safety glasses under the shield or hood. The hard coated ones are scratch resistant and also protect you from UV, which really helps if you are working around other welders.
                  fence and gate shop worker
                  At home...
                  Lincoln Power MIG 180....
                    Update ... Found some new wheels actually MADE IN USA at local farm/ranch supplier... Ring test is good, going to mount them up and true them up... Will keep everyone updated...
