How can i keep 1/16 in gap on 3/16 in plate on a 6` weld on a seamer
contraction problems with seamer
Originally posted by Blacksmith View PostPennies work good as spacers; right size and made of copper.Bob Wright, Grandson of Tee Nee Boat Trailer Founder
Metal Master Fab
Salem, Ohio
http://www.ceilingtrains.com/
If I understand correctly you have a 6' seamer and the joint is closing up while welding. The normal fix is to add start and run off tabs to the part and weld them on to the plate. If the hold down fingers in the seamer are set correctly the gap should not close up using this procedure unless the clamp pressure is to low.DrIQ
