clamp question
  • clamp question
    i would like some way of clamping my work in some type of vice grip / locking pliers gizmo so that it can be suspended above the welding work table. and have that vice grip attached to two arms which swivel and bend and is clamped to my metal work surface, so it can act as a ground conduit also. the vice grip end only needs to clamp up to an inch or so. i could probably fab something together, but does anyone know of a commercially available version of what i'm looking for? thanks.
    5 rules for happiness:
    3. live simply
    4. give more
    5. expect less
    Rigid chop saw
    Rigid 3" drill press
    4 X 6 horizontal band saw
    porter cable 1410 dry cut saw
    O/A setup
    TA 185
    MM 212
    Cutmaster 52
    get buissy net searching work-holding on the web
    Lots of unusual vices available (some viSes too)
    Even Ebay
    VG
    sigpicViceGrip
      Take the adjusting screw and weld an eye on it. Another amazing tip from the Edler Weldor!
        well, i couldn't resist the temptation to fab it. it is not the best looking thing i ever put together, but it works, and didn't have to spend a dime on it. i built it from stuff lying around my garage.
        3. live simply
        4. give more
        5. expect less
        Rigid chop saw
        O/A setup
        TA 185
        MM 212
        Cutmaster 52
          nice one
          Thats a pretty niffty contraption you came up with, although it does not look like it can handle anything that might have some heft to it. I always prefer to build my own jigs and clamps too. Good Idea.
          Don't sneeze with your hood down!!
            i only need it to hold maybe a pound or two. it seems to do the trick.
            3. live simply
            4. give more
            5. expect less
            Rigid chop saw
            O/A setup
            TA 185
            MM 212
            Cutmaster 52
              Absolutely beautiful. Pure function, and nothing else.
                That's the cleanest rebar I've ever seen!
                Pretty nifty contraption.
                Hank
                ...from the Gadget Garage
                MM 210 w/3035, BWE
                HH 210 w/DP 3035
                TA185TSW
                  $20.00 from Harbor Freight, about 1/2 that when on sale. "Helping Hands Clamp". I have one, but the pliers were poor, but easy to slice off and weld some nicer ones on.
                    I saw these the other day at Northentool for about $20 a pair....
                    Mike
                    http://www.stronghandtools.com/produ...uemagnets.html
                    George W. Bush saving your butt whether you like it or not!
                    Thomas Paine
                    HH210 w S.G.
                    Victor/Uniweld O/P
                    Dewalt Chop Saw
                      i checked northern tool, but didn't see the snake magnet. it looks like it was the only one they didn't carry. then i looked around at other places and couldn't find the snake magnet. has anyone seen this particular snake magnet from "strong hand tools" anywhere for sale on the web? i would certainly be interested in getting one. thanks.
                      3. live simply
                      4. give more
                      5. expect less
                      Rigid chop saw
                      O/A setup
                      TA 185
                      MM 212
                      Cutmaster 52
                        Northern tool carries Stronghand products, but not the snake magnet, it seems. Check this out...you may have a dealer close to you: I have some of those little magnets, and they are real useful.
                        http://www.stronghandtools.com/distr...hp?countryid=6
                        or here: http://www.eastwoodco.com/shopping/p...Magnet_3pc_Kit
                          hey, thanks Rocky D, for that gem of a find at eastwoodco. you are so helpful! do you know if the snake magnet is meant to be an electrical conduit for the ground? are the surfaces of the magnet metal, and therefore transfer the current to the cable? or do i have to connect the ground directly to the workpiece which is suspended?
                          3. live simply
                          4. give more
                          5. expect less
                          Rigid chop saw
                          O/A setup
                          TA 185
                          MM 212
                          Cutmaster 52
                            I wouldn't trust the magnet for a ground...use the cable ground...it's made of copper, and will carry the current.
