picked up a project in need of repair
champion 10000, kohler powered, fire it up, has full 120v at outlets for 5secs or less on every startup , then dies to nothing, the light on the field control board is on, checked bridge rectifier it seems to be good, if i pull the 1 wire that goes from the rectifier to the board and start the welder, i then get a constant 80v
i have taken the board out and inspected it, i pulled capacitors off board and measured caps are 1000 and have a reading of 870
seen posts with bad IGBT on Q5, haven't checked that yet
is there any other sports or things i should be looking at? thanks
