aab is my name i got welder that doesn't work need a tm245 manual need help
  • aab is my name i got welder that doesn't work need a tm245 manual need help
    i got a hobart champion welder 10000 genrator sr# LB237470 field current control board pc1 need tec mau TM245 my fuel shut-off solenod i don't have 12v on it aab need help
    look for a small transformer and measure you voltage going out to your solenid.you can trace the wire from your solenoid to your transformer or the board
      Hello,
      I have moved this topic to the correct forum.
        Just pull the solenoid from the carb, cut the end then unplug it. Problem solved. Of course this tip is for an emergency situation
          Thanks for the tip. I will surely do it as you have said. But I will try it later because right now I am writing on computer assignment and I already found the http://www.hardwaretimes.com/what-is...r-or-on-paper/ website through which I will take help to complete my essay assignment. When I am done with my assignment after that I will try it.
