GF-250 armature bouncing
  • GF-250 armature bouncing
    I just dragged home a running hobart GF250 yesterday with 200ci ford six engine for about $100 via horse trading. The seller claims to have welded with it 3x and on the final job there was a bang then the armature started dancing violently at the flywheel end of the generator head. Its aggressive enough to push the brushes out of the holders and ive watched it one time for just a few seconds to verify running condition. I presume a roller bearing ejected the ball bearings.
    My question is does this generator have a bearing at that end or is it supported by a flexplate that may have torn the center hub out? I am going to attempt a repair if i can get the parts and manage disassembly without too much investment. Are any special tools needed for getting this generator apart? Is it a full tear down or can that end be serviced by itself once unmarried from the engine? If its too big a deal or if the armature is bent i will part it out and the motor will became a stationary hydraulic pump unit.
    Any tips on where i can find service schematics and part numbers? Nothing came up on miller or hobarts sites for me.
    thanks fellas.
    thanks fellas.
    List all of the information on the machine's plate, and your email address.
      If it isnt pouring out tomorrow i will untarp and unload tbe machine from my truck then find the dataplate and post the info. Thanks.
        GF-250
        SPEC 5517F-1
        SN 10-4W-5988
          Check your email.
            Thank you keith, youre a lifesaver!
            So it looks like no bearing at the bellhousing end, which means ive got a bent armature or a flywheel/hub issue to figure out. Hmm
