Hobart g-213 service manual request and advice info
  • Mainer
    Hi, I just got ahold of a G213 Hobart. Does anyone have a wiring diagram for this machine? It makes AC power and welds with the DC, though the RPMs seem very low while welding. The starter appears to be operated 24v through the gen windings somehow. It is not working. I hand crank started it. Also, that weld and power and standby power switch seemed to do nothing. Was it normal just to manually dial in the rpms to get your volyage on these machines? If so why bother with that switch? A manual for the g213 would help alot! This one has a side mount gas tank, batts on top, and 12A buss fuses for the AC legs on the front panel if that helps to date it. Any tune up I should do electrically on the head not related to the Wisconsin?
  • mla2ofus
    check your email
  • 3wincoop
    I am new to this forum and just got my G-213 serial # 80WS03249 running but need a manual. thanks : [email protected]
  • Hobart Expert Keith
    Pmi, Check your email.
  • Pmi1924
    Hello, I am new to this forum too. I am in the same situation as others. I just bought a Hobart G-213 SN AAW-91717 and looking for a manual or any information I can get for it.
    Lazer, check your email.
  • Lazerdealer
    New to the site, very good info so far. I just acquired a g-213 but it has been previously sand blasted so there is no writing on the case anymore and need to know what the switches are for. It generates 110v but haven't tried the welder yet as I didn't get leads with it. Looking for a manual for the unit. Would be much appreciated! Looks very well built. Spec #413OB and serial AAW-58444 can someone e-mail a manual or is it too big?
  • CoreyBurton
    new to this site, but looks awesome. I am also looking for a repair manual for the Hobart G-213.
  • Prose313
    Hi my g213 has a twin wisconsin. I can't find anything about this motor,TJD-spec 325306-serial5452237.
  • Prose313
    Ok thanks for the info
  • mla2ofus
    One thing I forgot to add was to sure to use a known good plug wire. If the wisconsin wire is bad the test won't help.
    Mike
  • mla2ofus
    Could be bad rotor, cap or plug wires. With mag installed and the cap off use one of the plug wires with a spark plug on it grounded to the engine, hold the wire end on the contact that contacts the cap and crank it over. if it makes spark then you know where the problem is. If the elec start doesn't work then you'll need help to do this test.
    Mike
  • Prose313
    Hi everyone my magneto has spark at the coil I got a shock from it but when install it and crank it there's no spark at the plugs.any suggestions would be appreciated thanks uh
  • Prose313
    Sorry Keith thanks again
  • Prose313
    Hey Kevin thank you so much for the manual . I have the magneto out and cap off cleaning it . I got zapped by it so it has spark I hope I can get it running I can tell it sat in storage for a while
