Hello everyone,
I am in search of a service manual for a g-213 spec 5776-1 serial AAW-93945. I was recently given this welder and it was the first welder I used at 10 years old(27 years ago). Everything appears to work but I am trying to find info on what the dial is that says push to adjust that appears to be part of the charging circuit. Also more info on what holds the throttle wide open as I believe something may be worn out or missing. And last but most important some of the porcelain on the unit is broken so some of the rings are able to move a bit, I don't think these are available anymore so any ideas of a retrofit or work around would be appreciated.
