I thought maybe I'd throw this out here and see if anyone has any ideas until Miller Tech Support is open tomorrow.
I've got a Bobcat 225NT, production code LA which is a 2000 model. It runs and welds fine on CC processes, no problems there. However, while trying a suitcase feeder out yesterday, I found that the CV setting doesn't work properly.
When set to CV on the selector, the Fine Adjust knob is supposed to serve the function of voltage adjustment between 17-28 volts. However, in both DCEP and DCEN settings, the voltage is stuck around 26 volts and does not vary more than plus or minus a half a volt or so.
Anyone have any ideas on where to start with diagnosing this? It sounds like a component may be open, since the voltage is nearly maxed out. Diode? Bridge? Like I say I'll try and call Miller tomorrow but any suggestions in the meantime are appreciated.
