Plasma Cutter to portable generator?
  • Plasma Cutter to portable generator?
    I guess it’s been a while since I posted. Can’t believe my account is still up. I’ve got some projects coming up and I decided to buy a cheap plasma cutter. It cuts fine on 110v but it can run 220v. I decided to hook it up to my portable generator with the twist lock plug and use a 6-50R adapter.
    I flipped the plasma cutter on, everything for 220v lit up correctly. I dialed it up for 20 amps and hit the trigger.
    The generator immediately died.
    I’m guessing there’s a problem with a bonded neutral trying to run a 3 prong plug in a 4 prong outlet even with the proper adapter. Anyone have this problem before? How did you fix it?
    I pulled out my multimeter and didn’t find any shorts in the adapters, so I’m guessing it’s the generator setup.
    Lincoln 135
    Victor 315/2640 WeldIt 100FC/1350 knockoff
    Radnor 350 series regulators
    HF Bandsaw Clarke Chop Saw
    HF Bender and Scroller
    Jack of All Trades
    A garage full of crap
    And Credit Card Bills to Prove it
    First thing I would be suspicious of would be adapter.....
