No heat on new ironman 240 very upset!
  • No heat on new ironman 240 very upset!
    I set this on 3/8 for mild steel....would not penetrate 3/16 this welder has poor heat and is new im very upset demand a new welder
    crickets....
      Hi there, the parameter chart included with the machine is intended to be a starting point, these settings will vary based on material cleanliness, joint preparation, joint configuration, and even brand of wire. The door chart also shows settings that are geared towards a fillet/T joint configuration. Typically when welding surfacing beads on material as thick as 3/16" you wouldn't need/want complete penetration or burn through on the back of the plate. If you would like to chat with a technical support specialist to do additional troubleshooting please give us a call at (800) 626-9420.
        YOUR MACHINE is not doing what it states and your warranty dept is not fullfilling their warranty when your local clarksville TN "service dept" does not service...
          I DONT HAVE THE MEANS to drive 4 hours to nachville TN to have this looked at
            WHAT YOU HAVE HERE IS A MARKETING SCHEME. https://youtu.be/bSmMrQ6K-1I
              Hello, we don't have an authorized service location in Clarksville, TN. Take a look at our service locator tool to see the authorized service locations in TN. If you have concerns about service, warranty, or equipment performance please reach out to our technical services line (800) 626-9420, or fill out our contact us form. When applying a surfacing weld to plate, complete penetration is not expected, nor is it typically desired. 3/16" plate would also typically require some level of joint preparation for a full penetration butt joint.
                Thanks Hobart Expert for the comment about his "penetration" concern. I wanted to comment on it also but was waiting on others to chime in. I would like to know why He thought the weld should go all the way thru as I'm sure others would also.
                  your clarksville location service center does not service...they stated this over the phone...im supposed to travel in exces of 4 hours each way to get this serviced>?
                    Problem here is not with the welder its with the weldor, he does not understand the process and is pissed because the warranty did not transfer from original purchaser and he does not even read replies from Hobart Tech or anyone else.... If he would ditch the attitude, he might get some success.....
                    How about that "pumpkin"....
                      Need to start at the outlet here. Every once in a while one of thee do not work right but its pretty rare. I bet money its an operator control problem.
