Would this pass?
  • Would this pass?
    Pass what? Looks like undercut on both sides of the bead.
    Blacksmith
    Stickmate LX AC/DC
    Big cheap (Chinese) Anvil
    Hand cranked coal forge
    Freon bottle propane forge
    HH 210 and bottle of C25
      Not the worst of a weld or the best of a weld. A weld none the less. I'm not sure what the Blacksmith calls undercut, but when I blew it up, I didn't see undercut. A few slag inclusions...but I didn't see undercut? As far as passing go and collecting $200, no. That's not how they test welds, but you filled a corner with metal and that passes for something in my books.
        Yes. I mean, no.
        Depends.
          Looks ugly but to say it passes... Can't comment needs to be tested....
            What is this supposed to be, and what do you really want to know? Describe all conditions and purpose of the weld, and what standard or code you are trying to meet, and someone might give you a clear answer.
              If your just learning how to weave with stick, your going in the right direction. I don't see undercut on the toes, that's good. Consistency needs a little improvement. Restarts need a little work. The bottom where you started is a little under filled. Don't be afraid of using more heat.
              Lincoln Idealarc 250
              Miller Bobcat 250
              Thermal arc Hefty 2 feeder
              Thermal Dynamics Cusmaster 52
              Torchmate CNC Table
                I was hoping he'd come back with a bit more information on the rod he used? Maybe the power source and current? Judging appearance, I'm inclined to think as mentioned he's headed in the right direction, but could use a bit of guidance to lay the icing on the cake.
                  Looks like a nice fancy pattern, If that's what your aiming for? But certainly not a good solid well burnt in weld that would stand up to a lot pressure.
                    If You were on a job site with a welding Eng. Sorry No.
Name:	Hot vert 2.JPG
ID:	705137Click image for larger version
ID:	705138Click image for larger version
                        You showing off, looking for suggestions, or is this a challenge to see who has the game and who's a player?
                          Little undercuts on this one. Click image for larger version  Name:	lohi vert.JPG Views:	0 Size:	32.3 KB ID:	705154 certainly could have cleaned the plate first.
                            I learned along time ago that beauty is in the eye of the beholder and when it comes to welding, beauty is usually the result of a number of factors that typically accumulate with the consistency of the welder and his movements.
                            Your recent pictures show a much greater consistency. Having said that, while most were taught to weld with the end goal to accomplish making pretty beads, I would advise that the material thickness should be considered when such a volume of welding is being addressed.
                            In the first pictures, the weld presented got extremely hot. In theory, that should then have required of you to address that build up of heat by stopping to let it cool, by adjusting your parameters down accordingly or making allowance for the heat that's built up with faster more frequent movements and adjusting those movements/ manipulations to deposit a consistent amount of metal.
                            Two pieces of 1/8" flat bar don't require that much weld to make an angle iron. You can, but it's not required. Your first pass in the last photo was plenty. More means the material is overly reinforced with weld, which transfers stress to the edges. I'm sure however it makes for a very stiff corner.
                            You mention a little undercutting. You don't have to, but trust me when I say, I've seen worse and it doesn't mean the weld isn't suitable, strong, or unfit for purpose. I can be, but most likely not. It's not as detrimental to the worlds end as they'd have you believe, and in the real world it's the equivalent to a wrinkle on a very pretty face.
                              It is extremely hilarious that you are trying to teach Sberry to weld!
