I am building a BBQ pit out of 22 inch pipie quarter inch wall. It will be 28 inches long. What kind of ideas do you'll have for wheels for it? They will have to be fairly sturdy.
Wheels
If you have access to a large bandsaw, cut some 2" slices from large steel pipe ( say, 8"), then make a simple jig (could be wood) to hold a piece of thick walled pipe centered, drill and tap for zerk fitting, then weld some rod or rebar in for spokes. 'would add a real hand crafted look!
It would be a snap to make it to accommodate a bearing, but you really shouldn't need one for occasional moves.Last edited by Hotfoot; 11-28-2010, 10:34 PM."Good Enough Never Is"
Here is what I did on a pit I built awhile back. None of it is exact and there is defiantly more play then whats in a bearing but I bet it won't seize up either.
Stickmate LX 235 AC / 160 DC.
MM211 AS and Spool-Mate 100.
Spectrum 375 X-Treme.
O/A Medium Radnor Torch, Large Victor Torch.
Milwaukee 14" Chop Saw.
4 x 6 Horizontal Band Saw.
Rockworth 80 Gallon 2 Stage 16 SCFM @ 175 PSI , 15 SCFM @ 90 PSI.
Jackson Passive Shade #5 for the plasma.
I almost forgot the Hobart XVP AD Hood.
Speedglas 9100x
Projects and Misc Albums
http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
Originally posted by Tom37 View PostNone of it is exact and there is defiantly more play then whats in a bearing but I bet it won't seize up either.
