Old Welder
  • Old Welder
    Airco 180amp AC
    Old Airco 180 amp A.C.
    Yup, that's what it is...looks like it is well cared for, too.
      It was my grandpa's then it sat for years in his garage. Then he gave it to my dad. It is now in storage. It has only burnt 1/2lb. of rod since we have had it.
        Sounds like it's time to rectify that situation.
        Hobart HH 125EZ
          I don't think that one has a rectifier, it's an AC only.
          It is a nice clean machine, made by Miller IIRC.
            Oh...I saw that heading, and thought it was a message for me...
              Fart starts with an "F".
                Anyone have any idea on the value of this? Ground and work leads are complete and in good condition considering age.
                  Unfortunately the leads and the copper in it are probably worth more than the welder. Maybe $100. Location is everything.
                    My grandfather had one like it . . . first welder I ever used. I have no idea where it is now.
                    Dynasty 300DX
                    MM350P
                    Hobart Handler 120
                    Smith LW7 , AW1A
                    Smith He/Ar gas mixer
                      In that case it may just stick around a little bit longer
                        Take it out and use it. Don't worry, you won't wear it out!
                        "Stick-man"
                        Miller Shopmaster 300, Super S-32P
                        Lincoln
                        Commander 500D
                        LN-25
                        Idealarc 250
                        5 Idealarc Tig 300/300's
                        Hypertherm Powermax 600
                          We really have no use for it. We have a MIG welder and every bit of welding that we normally do is automotive, primarily sheet metal. A machine such as this is little more than a paper weight to us. In fact I feel that with the MIG technology that arc welding is an archaic outdated process.
                            Maybe for the automotive industry. But try migging outdoors with a breeze. I've done it, but you always seem to get a gust of wind right after you pull the trigger.
                            And fluxcore works, but do you really want to hook up the feeder for a small project. To me, it's easier to just pull the leads and use a stick. Stick welding will not be archaic or outdated, not in my lifetime.
                            "Stick-man"
                            Lincoln
                            Commander 500D
                            LN-25
                            Idealarc 250
                              While it is true that stick may not be out dated its often of no real need for most common garages with a mig. The fact that they are in auto related work even makes it more so. Unless there is some special need those machines collect dust. Even I would rarely use it and I got more bigger broke shate than most people. If I had any kind of real need would likely want a DC one anyway. I use a little stick mostly when its convenient or out the door but could easily get by with a feeder if its what I had.
