My first time
  • My first time
    Sorry about the pictures--the camera didn't want to focus on the steel.
    So, this is my first attempt at welding.
    Well, you're off and running! Tell us what you are using (Flux Core Wire welder??), waht thickness that steel is, etc. To me, it looks like you are moving abit too slow, and possibly you power setting is too low.
      Hobart EZ 125 handler. Its set up with .30 wire. Unfortunately, the only thing I have to practice on is 1/8 flat bar I got at Farm and Barn (thinnest they had), and I set the machine to 1/16 (seeing as I don't have the thicker wire). I'll try again tonight and up the power setting, but don't know if that will work with the thinner wire. I'm just trying to lay beads anyway.
      I thought I was moving too fast! I couldn't see any metal actually "puddle"--just the arc. I felt like I was racing with the wire--I want to go slower but the wire kept on coming. Maybe I need to tighten the retainer knob inside?
      On the bright side: 1) I didn't hurt myself; 2) didn't set my fiance's place on fire; and 3) the two pieces of metal pictured actually are stuck together.
        1/8" is fine , thinner is more difficult. Just try upping the power setting. Listen for the sound of Bacon frying...when you hear that...you're cookin'!
          You've mis-read the instructions; the machine is designed to run .030 wire through its entire thickness range. Set the machine for what the material thickness is, that's the whole idea.
          Hobart HH 125EZ
            I just got a Hobart EZ Handler 125 and its nice for me considering i'm just using it for little projects around my house.
              No I didn't. See page 20. 12 GA and up requires .35 wire
              http://www.hobartwelders.com/om/0900/o923c_hob.pdf
                Greenhorn - I think if you look closely at the settings on page 20 (actually page 16) you will see that the 0.030 wire line goes all the way across. You can use either 0.035 or 0.030 wire on the higher ranges.
                Lincoln 175HD
                Miller Thunderbolt AC/DC
                  yeah ya did
                  Look again- there is a Solid line for .030 all the way from 18g to 3/16th
                  .030 is good from 18g up to 3/16th
                  .035 is good from 12g up to 3/16th
                  12g does not require .035 what it is showing you is that .035 is good for 12 gauge and up and NOT good for anything thinner than 12g
                  Ed Conley
                  Screaming Broccoli, Inc
                  MM252
                  MM211
                  TA185
                  SO 2020 Bender
                  Miller 125c Plasma
                    **** Smyrna that is the 2nd time we have posted at the same time
                    Ed Conley
                    MM252
                    MM211
                    TA185
                    SO 2020 Bender
                    Miller 125c Plasma
                      Ed - yeah but I must have beaten you by at least a mili-second
                      Lincoln 175HD
                        Must win a lot bids on E Bay
                        Ed Conley
                        MM252
                        MM211
                        TA185
                        SO 2020 Bender
                        Miller 125c Plasma
                          I stand corrected. Apparently, I am dumb.
                            Don't think you are dumb Greenhorn. The chart is a bit hard to read, since the 0.35 line has a heavier weight. As a new welder there is a lot coming at you all at once. It is not as easy as it looks, so keep practicing and learning.
                            Lincoln 175HD
                              just remember with spacing and being humped up high that means fast and cold...dont know what shade lense you are using but you need to be able to see the puddle not the flux...the flux will lie to you
