I'm trying to weld a Tee Joint using 5052 Aluminum and 4043 stick. One piece is 3/16" being attached to 1/8". Using 1/8" 2% tungsten and argon. Cleaned all surfaces with grinding disc. Arc starts fine but will only hit one piece of material...not right in the middle. I either burn through or the bead just attaches to one piece of metal. Using a foot pedal and heavy pressure to get started but then back off some to avoid burn through....set on Weld, not step. Got machine turned all the way up to 185, pre flow 1 sec and post 5. Pressure set on 23.
Took the same material to my shop where I have a synchrowave 250 and ran a perfect bead on first try. There I had machine set on 220 but only used about 2/3 of the pedal. Difference was that a good wide arc shot right into the middle of the joint and formed a good pool. I'd rather use my home machine as I have a large set-up table there and am working with a lot of bends and round surfaces. Thinking that there's just not enough power in the TA to handle the 3/16" part of the metal although it will burn right through in no time at full pedal.
Any ideas or suggestions? Thanks
