Today's project was to try to put together an ice chisel. We've been doing a lot of ice fishing this year and although we have an auger, I wanted a backup. I made the blade out of a piece of mild steel, 3/8" thick by 4" wide. I used a stepped tooth design kind of like a Jiffy chisel I saw. The blade is probably going to be too wide, but this is just a prototype.
Anyway, I realized that the mild steel blade probably wouldn't stay sharp, so I grabbed some 30 year-old hardfacing rod that my father had given me. I have no idea exactly what type of rod it is, all I was told is that it is hardfacing rod. The rod is 1/8" and I experimented with different amperages. I ended up at about 100 amps. The rod would only run with a fairly long arc. And it was almost impossible to get anything but a thick amount of coverage. And where the blade came to a point I would just melt through it.
So after the hardfacing I had to pretty much start over with profiling the blade. And of course, now that the blade was hardfaced it was much harder to grind it to shape. I was amazed at what a difference it made. So is this the wrong application for hardfacing rod? Is there a way to do this without just goobering it on thickly?
