Calculating how much TIG rod for project?
  • Calculating how much TIG rod for project?
    I have a TIG project, basics are welding DOM steel tube that is .065" wall, to itself, to 3/8" and to 1/4" steel. I come up with a generous estimate of 165" of welding to be done.
    Is there a formula to get a good idea of how much rod I will need for this? Or at least an educated guess?
    Looking for recommendations on what rod to use as well. I've been told make sure its coppercoated, but I don't know much more beyond that. I'm outsourcing the welding, just providing the rod.
    Much thanks for the help.
    If........
    If the fit up is good I'd use 2" of rod to each inch of weld.
      Gunna be a lot of rod then...
      Any recommendation for type of rod?
        nah
        That's about twenty leaving room for you to drop it at the end :-) I'd use my standard Er70S-6 but some might prefer the -2 or -5 versions. I just like the way the -6 works for me on the Dynasty 200DX. If the fit is not good you could go through more rod but rod is the inexpensive part of this job and a lot will depend on the skill of who's tigging it. I always use a 3/32 tung on this material.
          Well, thats good to hear. Thanks for the recommendation, off to the welding shop I go.
            10-12 36" lengths of 3/32 filler should do the job.
            DrIQ
              Agreed
              I always use 18 inchers so I guess I should have been more specific.
                Thats good, should be nowhere near as pricey as I had thought then. Best part is the work is free
                Thanks again guys
