Handrail Pipe Wall Thickness?
  • Handrail Pipe Wall Thickness?
    Doing some handrails and was woundering what wall thickness of tubing/pipe you guys use. Thanks
    NorthridgeFab.com
    handrails
    i have just used basically anything on hand,but for a professional look i have used 2'' sch 40 you can also use reg. blk pipe, i've seen that done before cheers snakesaver
      I've never used pipe less than sch 40 and 16 ga on sq. tube.
      Don
      Go Spurs Go!!!!!!
        Alright I'm good then. I was planning on using a 1-1/2 ID Sch 40 pipe and wanted to make sure it was not too thin. Thanks
        NorthridgeFab.com
          I've always used 1 1/4" Steel pipe. It is about a sch 40 wall thickness and is 1 5/8" OD. The steel pipe has a little better outside finish than regular black iron pipe normally used for piping/plumbing.
            What's often (incorrectly) called "Black Iron" pipe IS mild steel.
            Hobart HH 125EZ
              Right, he is taliking about structural pipe.
                I got one more question. Before on rails I just bolted a plate down. But on this job it would be faster to just core drill holes. My question with doing the core drill holes is how far past the concrete should I set my posts? The concrete it 4'' thick. Also what suggestion on concrete for the hole other than epoxy?
                NorthridgeFab.com
                  ENJOY
                  Ed Conley
                  Screaming Broccoli, Inc
                  MM252
                  MM211
                  TA185
                  SO 2020 Bender
                  Miller 125c Plasma
                    On those rails that I built I am pretty sure we added 6" to go through the concrete and into the substrait.
                    I didn't core drill nor anchor those. The cement contractor handled that part of the job. You might want to check with a local fence contractor to inquire what they use on fence posts.
