Why can't I see?
  • Why can't I see?
    I tried my first weld the other day. Are you supposed to be able to see what you are doing when your lens darkens? All I could see was the glowing metal or arc? Couldn't see nothing of what I was trying to weld. Did ok on tacks but when I tried to run a bead, had no idea where I was going.
    Two questions...what type of welding and what shade of lens?
      You should have very good light on what you are welding, especially starting out...next..Are you using an Auto-dark helmet, or fixed shade??? Fixed shade takes more "getting used to",but is the old time standard. If you are using an auto dark, what filter hade setting do you have it set on?? Tell us a bit more, and we may be able to help a bit more!
        Good lighting is a must, just make sure it isn't at the angle behind you where it comes into your hood from behind and reflects off the inside of your lens. When welding indoors, I usually have a 500W halogen directed at the work. The overhead fluorescents usually aren't enough for all positions.
        My 9-12 variable is almost always at shade 9. It still fully protects against UV, even when in its clear shade 4 state, which is nice for plasma cutting.
          check your helmet, some comedian might have replaced a clear cover lense with a shaded one! nothing like trying to weld with two sandwiched shade 10's
          P.S if you want to do this to someone, use a shade 5 it takes them much longer to catch on
            The first question that comes to MY mind is, "How old are you?" If you're one of us guys who's in the, well... 'prime of life'... then aging eyes are a real handicap in this endeavor. I have a much more difficult time seeing through the lens now than I did 20 years ago, complicated by trying to keep bifocals in the right position.
            Hobart HH 125EZ
              I am little older still and wear tri-focals. Every now and then when I don't hold my head just right I see two rods or wires.
              Honestly I didn't know about having a lot of ambient light available until I read your post. I didn't think it would make a difference through the helmet. Thanks you for that tip. I will try it.
                Or carbon paper,
                L*S
                  You can also get the inserts for you helmet for cheater lenses.
                  I was using the safety glasses with the bifocals and helped, but after getting the insert for the helmet, hey I could even see the weld puddle while doing flux core!
                  Miller 140 A/S
                  HF Flux Core
                  Dewalt Chop Saw
                  Smith O/A Torch
                  Ryobi Grinder, Craftsman & HF Grinders
                  Harley Electra Glide Classicsigpic
                    Or go to your favorite cheap junk store & get some 2-2.5 power reading glasses.
                    Jim
                    I can weld but I'm not a welder.
                      My Stuff
                      I got a Hobart Handler 140 and an auto darkening helmet that's supposed to have a #10, I believe, lens.
                        Yea, it's auto and if that's what the knob on the left side is, 12-1/2. I thought that was a timer. Guess maybe I should have read that manual.
                          I was outside, perfectly sunshiney day. I may of just found out about that knob. Mine goes from 8 - 13 and was at about 12-1/2.
                            Nah - brand new. They would have had to do that at the factory, cause no one comes around here unless they're with me. I raise Doberman Pinchers.
                            That sounds like fun though.
                              That's what I was trying.......flux core. As soon as it started to arc though, all I could see was a little yellow ball. I guess I will need a lot of practice b4 I try anything that someone else might see.
