I have to make a fixture and would like to use 1/2" B7 threaded rod as part of it. I need to join short lengths of right hand and left hand threaded pieces.
Ideally a threaded coupler would be perfect but I can't find one for fine thread so I thought about making one. My plan would be to take a solid piece of square steel about 3" long and drill a hole through the center of it the size of the rod I'm using. Then simply insert each piece of threaded rod 1 1/2" into the square stock and weld the rod in place on both ends of the square stock.
I'm a hobby welder with limited experience at this point and wonder whether
B7 rod, which I know is fairly hard stuff, can be welded with my HH175?
Thank you
Thank you
