Hello, I've built a bumper for my truck out of 1.5 x1.5 x3/16" steel tubing. I used flux core wire to weld it together. I used pointed hammer and a wire wheel on my grinder to clean some of the welds but I can not get to some of the welds. What can I use to get the welds clean so I get the bumper ready for primer and paint. Thanks, Fred
Cleaning flux core welds
Needle scaler.*** Disclaimer ***
The two best ways are the needle scaler as stated or a media blaster. HF had two versions a full size version of the needle scaler 19 needles and a mini needle scaler. http://www.harborfreight.com/cpi/cta...temnumber=1108
http://www.harborfreight.com/cpi/cta...emnumber=96997
With 12 needles for smaller area's. An added benefit is you can use it on thinner materials for surface texture,designs etc.
On the larger one you can remove needles so you can change the pattern or also get in to smaller area's. But the length of the gun will be the same.
If you don't have a blast cabinet, you can get one of theses. I have had one for years and it is great keeps the mess down and if they come with the shaped rubber nose cones you can get into the weld area. http://search.harborfreight.com/cpis...ster&Submit=Go
They have them all most everywhere tools are sold now a days.
If you need a smaller area blaster, one of the air brush companies makes an air eraser:
