Gold colored coating on unistrut?
  • Gold colored coating on unistrut?
    What is the gold colored coating on unistrut?
    I was going to pick up some unistrut scraps from a construction project at work to practice mig welding on. But if that coating is hazardous when burned I'll look for something else.
    Thanks,
    Ralph Wenzl
    It's a zinc-chromate conversion coating.
    Hobart HH 125EZ
      You could always grind it off thats what I do with it.
      Matt
      MM 175
      Ideal arc 250
        ...and we assume there is no compressed gas or oil in that strut....
          Hotfoot... this is unistrut:
          Hobart HH 125EZ
            Electricians would come to me with that stuff to make hangers for buss ducts and support frames for electrical panels. The green powder coated stuff was had to strike an arc on difficult to ground without grinding off a clean spot.
              I tried but it just won't stay in the Unistrut
              Ed Conley
              Screaming Broccoli, Inc
              MM252
              MM211
              TA185
              SO 2020 Bender
              Miller 125c Plasma
                ..guess Unistrut...monoshock...I figured a Unistrut was a monoshock mounted beneath the seat on a unicycle..or somethin' like that... I never knew what those electrical racks were called, but have noticed them, and their nifty attachments, in the big hardware stores...
                  Unistrut gets manufactured by lots of different outfits to lots of different engineering specs.
                  If it's gold colored, it's uaually anodized; galvanized is galvanized; some is painted with the toughest acid-reisrant paint I've ever tried to remove, etc.
                  I like it for projects where it is strong enough for the application because of all the holes. Makes mounting real easy!
                  Hank
                  ...from the Gadget Garage
                  MM 210 w/3035, BWE
                  HH 210 w/DP 3035
                  TA185TSW
                    Steel can't be anodized.
                    If it looks like this, then I'm tellin ya, it's zinc-chromate.
                    Hobart HH 125EZ
                      Unistruts are made in aluminum as well
                        Ok.
                        If it's steel unistrut, it's zinc-chromate; if it's aluminum unistrut, it's usually anodized. If it's cold Kettle One, it's usually drank.
                        Hank
                        MM 210 w/3035, BWE
                        HH 210 w/DP 3035
                        TA185TSW
                          I've seen a lot of green unistrut. We made a rack for a painter one time to hang his paintings on to dry. This guy gets big bucks for his stuff, I'm still trying to figure out just what the **** it is.
                          Willy
                            Willy
                            Abstract dollar signs
                            Ed Conley
                            MM252
                            MM211
                            TA185
                            SO 2020 Bender
                            Miller 125c Plasma
                              Yup. It's steel unistrut (the big boy's erector set) and that picture is exactly what the coating looks like.
                              So I think I'll look for some other kind of scraps to practice on.
                              Thanks for all the info guys.
                              Ralph Wenzl
