fish-mouth tubing
  • fish-mouth tubing
    What is a good, accurate way to fish-mouth round tubing? I have a variety of tools including a drill press. Thank you
    Tube notcher.
    Ed Conley
    Screaming Broccoli, Inc
    MM252
    MM211
    TA185
    SO 2020 Bender
    Miller 125c Plasma
      Chop Saw...
        bandsaw
        Ed Conley
        MM252
        MM211
        TA185
        SO 2020 Bender
        Miller 125c Plasma
          If it is small enough I use a hacksaw and file, like these guys
          http://www.youtube.com/watch?v=KIxCdTRkRHo
          For a template to glue on, or make a plastic reusable template use:
          http://metalgeek.com/static/cope.pcgi
          or, if you want to go industrial strength:
          http://www.tubebender.net/notcher_tubeandpipe.htm
          Lincoln 175HD
          Miller Thunderbolt AC/DC
            Originally posted by Hotfoot View Post
            Chop Saw...
            Please explain the chop saw technique.
            Robert
            Snap-on (Century) 110 Mig
            Ridgid Chop Saw
            Makita 4" Grinder
            Quite a collection of scrap
            Functional Stuff is painted, my art rusts.
            The greatest lesson in life is to know that even fools are right sometimes. - Winston Chruchill
              Just like the Bandsaw technique
              Ok, you put the stock in at an angle, cut the stock, turn it around and cut the other side at the same angle. It is like trying to put a point on the Tubing. You'll see what we mean when you make your first cut.
              There is a thread- I'll try to locate it.
              Ed Conley
              MM252
              MM211
              TA185
              SO 2020 Bender
              Miller 125c Plasma
                OK. I got it. Took a little while. Seems sometimes I engage mouth (or typing fingers) before I engage brain.
                Robert
                Ridgid Chop Saw
                Makita 4" Grinder
                  Works slick with 30 degree cuts. Some guys trim the points off, some leave them on. I makes avery nice T Joint. Somewhere on this site the table of what degrees fo what angle, etc., but for my non-critical welds a yardstick and chalk have given me enough 'eyeball' to put the joint in. All mine are non-critical, with no safety element involved....(unless it collapses on someone)...
                    Try this calculator for chop saw coping.
                    Larry
                    http://snip.awardspace.com/
                    " Time and hard lessons are one kind of wisdom"
                      Tube mitering program
                      Here is a program a lot of bicycle biulders use to miter tubing.
                      http://www.ihpva.org/people/tstrike/...ng/tubemit.htm
                        I like this one:
