NEW Broco 3/8"x18" Cutting Rods (66 Rods/25lb Box). $200 per box
  • NEW Broco 3/8"x18" Cutting Rods (66 Rods/25lb Box). $200 per box
    i have 4 boxes i am getting rid of.. i am new to this forum but if you want referances i am vesport on ebay with 100% feedback.. and i am a member of the VWvortex.com under onequickg60
    i have4 boxes i will no longer need got rid of the broco cutting system and the guy who bought it said he has enought rods..
    these are the 3/8 18inch rods they sell for close to 300$ a box but i want $200 each i just want them gone.. boxes weight 25lbs each never been opened..
    here are some specs from Broco page.
    Description:
    Burning in excess of 10,000° F at the tip, Broco® Underwater Ultrathermic Cutting Rods cut or melt virtually any known material. Broco's patented rod design features alloy core wires retained by circular crimps. The special design prevents burnback into the torch, making Broco® Underwater Ultrathermic Cutting Rods the safest on the market. Ultrathermic Cutting Rods can be bent 90 degrees or more to access hard to reach places without restricting oxygen flow or causing insulation to split or flake off.
    Ultrathermic Cutting Rods may be used with a maximum of 150 amps to assist in the burning process but have no electrical requirement. Once ignited, they continue to burn as long as oxygen is supplied or until the rod is consumed. Broco® Underwater Ultrathermic Cutting Rods are available in 1/4 inch and 3/8 inch diameters. Standard length is 18 inches. Broco® offers 36 inch Ultrathermic Cutting Rods for heavier jobs allowing more burn time between rod changes.
    any question you can email me at [email protected] willing to also trade for a decent wirefeed maching nothing to big basic 110v unit that can handle sheet metal and about 1/4 inch steel..
